Bigsexy
So I had another thread but now have a lot more to add to it. My truck will crank with no start. It all started when I changed the bolts on my battery cables. It started once after that but I shut it off necause it was idilling rough. Ive checked all the fuses and relays along with replacing the batteries. Ive swapped ipr, idm, pcm, alternator and gp relays. The glow plugs relay is getting the correct power. I have had it hooked to a modus and a.e. with everything looking good. We have even tried starting it wih starting fluid and nothing happens. I have plenty of fuel coming out the drain and return. We thought it could have been something with the alarm but its all been disconnected. I need some new ideas to try as ive tried all I can think of and then some. Most of my plugs have signal and voltage. I really need to get it figured out asap as I have bulls I have to get to stock show this weekend
