Not sure hype is the right word, but you have to expect the right thing from the crossover.
There is NO power benefit.
There is NO longevity benefit.
There is NO economy benefit.
It has nothing to do with deadhead rails...that's a FUEL issue.
It will NOT increase ICP in a truck with ICP drop-off problems.
The ONLY thing an HPX line does is balance the pressure in the HIGH PRESSURE OIL rails. It helps to take the high/low spikes out. The graphs on my site show the difference with and without the HPX...and the customer testimony tells me it's not just imaginary. Not every single truck will produce a significantly noticeable difference, but a very significant number of customers have reported a noticeably smoother idle and overall operation (throughout the RPM range).
So...if you have the extra money and would like to smooth out how the engine runs...try one. If money is tight and you don't care if it runs smoother...save your money or spend it elsewhere.
