ja_cain
- Joined
- Aug 10, 2013
- Messages
- 4,597
- Reaction score
- 2
I finally got around to installing my Hydra with GH tunes last weekend. So far I love driving in the Street Muscle tune (80 to 100hp increase) as long as I don't get on it too hard and get the revs up too high. It has definitely revealed some weaknesses on the oil side though. I don't want to be to hasty and blame the hpop as it could be a sticking IPR or leaky injector o-rings. The motor has about 155,000 miles on it with everything being original so it could be one or more of those things. I wish there was an easy way to discern if the IPR was sticking or not performing up to snuff but I don't think there is a way (injector o-rings could be causing this but need to pull vc's to check those). It runs like a turd after a real hard run and will not maintain ICP on a hard pull on the highway as the %DC approaches the maximum of 65% and the pw starts to go skyward.
I plan on doing some heavier towing in a couple weeks and look forward to seeing how it performs relative to stock (on the same route). That all being said, the truck is so much more of a joy to drive. I also still have the bellowed up-pipes/******d pedastal to install and some new cac/intake boots. This is definitely some low hanging fruit that I look forward to taking advantage of.
If I end up pulling the injectors, it will be to replace them not just the o-rings. I am really torn on whether to go with the 200% hybrids that Charles is running or just run some AC codes with a 30% nozzle. Hopefully the injectors/injector o-rings still have some life in them and it's just the IPR. I think I am going to just replace it since it has a lot of miles on it.
One other thing, if any cares to read this and they are attempting to clean their J3 connector with the scotchbrite, just hold off and get a brand new brass brush. It worked much better than the scotchbrite. I started out with the scotchbrite and felt it was too aggressive and switched to the brush and it worked beautifully.
