bigwheel
We are trying to figure out what might be going on with this truck on a cold start and idle smoke issue. The Truck will fire right up after having the GP run one cycle. Seems like no issue there. We have ohm all GP and checked GPR and all seem to be working like should. With the truck running there is quite a bit of fuel smelling smoke. It truck drives great. We have done a lot with the tuning on reducing the amount to fuel delivered. Helps a little but seems like it is not just an issue with tuning. Is there something that we should check to see if working the way they should? Like sensors?
This truck does live at 8000 feet so that does play a part in which we have the tuning adjusted for. It is a 2000 zf6, 200/30 GTP38R reg return.
Any ideas or thoughts would help out greatly.
Thanks
Thanks
