DigiKey P/N for 10-110 models:
SMD type, 75.0 kohm 1/4 watt 1% p/n 311-75.0 KFRCT-ND
Axial type, 75.0 kohm 1/4 watt 1% p/n 75.0KXBK-ND
DigiKey P/N for 120 models:
SMD type, 73.2 kohm 1/4 watt 1% p/n 311-73.2 KFRCT-ND
Axial type, 73.2 kohm 1/4 watt 1% p/n 73.2 KXBK-ND
SMDs are the block style ones like the original ones in the IDM. Axial ones are like the regular resistors you see at the "Shack". These resistors are close tolerance (1%accuracy), stable with high temperature changes, do not change value over time and best of all, don't cost much more than the "Shack's" junk. Regular 63/37 electronic solder works great here.
As far as the 120 models lasting longer? I have an original JoeServo modded 100 model IDM that's at least 10 years old and still works great.
