Injector tips.
brianb7.3
kilbourne,il
Have a 2009 with a set of tow compounds..would a set of 30% or 60% injector tips yield me any more horsepower?....I guess the real question should be what is the limit of the stock pump?....I'm asking because I have pulled a sled a few times...this will be my last hook for the foreseeable future and I want to make it good.. I want to give my all on an injector tip budget........OUO bars axle tubes welded ...ratchet strap the coils on all pulls.....any ideas?
ncollins64
winchester springs, tn
Do you have dual k16 pumps? If not and you throw bigger nozzels in the mix, you could potentially loose power from dropping rail pressure. Whose turbos do you have?
ncollins64
That seems like the norm. You can do low to mid 600s on stock nozzels with supporting mods. I wouldn't do bigger nozzels unless I was doing dual pumps, studs, etc. Good suspension, bars, stops, all can make for a better setup.
Lipka101
Maryland
I've only ever heard of 15% nozzles successfully helping a truck on stock single pump. But with very minimal gains for the $
Sent from my SM-N910V using Tapatalk
