I'm pretty sure I'm getting bad sticking in my injectors cause it's missing at W.O.T. If I need a set of injectors I thought of running WD injectors. What's the better route buying injectors with stock nozzles 175/stock or 175/75??
Also with out studs will it hold if I'm not beating it to death?
03 f250 6.0 Sct with innovative tunes 5in exhaust coolant filter blue spring 6in lift 20x14 on 37s
