fordornothing
So since I have a severe dislike for the ZF6 transmission, I was wondering what manuals came behind the T444E in the international trucks. Did ay of them have a 10 speed?
Why do u hate the zf6? I love em
The 6+1 doesn't have a higher final gear ratio than the zf-6 though does it? It just has more in-between gears which depending on how you use it, could be beneficial.
From what I have seen, they do not bolt up directly to the 7.3. You will need the adapter plate to go to a SAE housing. That same adapter plate thought, will let you bolt up any SAE trans which opens up a LOT of options depending on what you are looking for.
Where's Charles LOL
The 4wd internationals ran a divorced t-case.
I would skip the 6+1 they shift like butt. Eaton Synchro-6 would be my choice.
