Just got my 38R...
Lang
Is this going to be a problem? Obvious assholes dropped it!
Lang
Where can I buy a just a replacement? Gotta get a price for UPS
thats nothing to worry about. I tore the housing off mine and welded a bolt head on it and made it so I can adjust it with a wrench or socket.. it only opens on spring pressure this way... 99% of the people on here delet that red line to begin with cuz factory gating is set at like 26lbs.
PSD POWER007
Columbus, GA
Just adjust the actuator arm and put maximum preload on the spring and not worry about it...unless you are running big injectors.
PSD POWER007
Columbus, GA
They are just 160/0 so I'll try
I have mine adjusted to full preload so that it can't open. That's with 175/80's. My back pressures never get higher than 40-42 lbs at 36-38 lbs of boost. You can keep the red line hooked up for a clean stock look. ;-))
