You got a shorted wire somewhere. Time to start tracing the harness. You can buy a 20 amp circuit breaker to use for testing so you dont blow up a bunch of fuses.
Then there is no easy way, start chasing wires. Do you know anybody with a power probe. That may speed the process up a little. You could ohm the power wire to ground to make sure it is a dead short.
