I think I saw somewhere that when you remove the fuel bowl (doing efuel) there is a wire that is no longer used that is a keyed on switch to activate my new pump set up.
any ideas which one it is
Yeah that would be the fuel bowl heater wire.It's on the drivers side of fuel bowl,it has the big rubber boot on it.It's right under the fuel restriction sensor,and it's the bigger one.Hope that makes sense?
There's the fuel bowl wire harness and the only one you need is the one I mentioned.I have a nice pic on my phone of the fuel bowl with everything labeled.
