Enoch
- Joined
- May 19, 2011
- Messages
- 272
- Reaction score
- 0
I've been trying to figure this out for a while. At first I thought it was the boost leak I had but fixed that and actually got worse.
Me and a friend changed the pedestal o-rings when we fixed the exhaust plenum boost leak
in which the guy helping me said that one of those clips on the exhaust side of the turbo got bent somehow during the process and that one side wasn't hooked in all the way.
Power just seems like it's being blocked, or it's not breathing.
Could the EBPV be getting stuck in the almost closed position or just not opening up all the way due to that clip being bent and not on all the way?
Truck has the 38r, 6637 Air Filter, HPX, and 4" Magnaflow turbo back exhaust and an SCT tuner.
When I accelerate the EGT's go up super fast, boost is low and although I pick up speed it's not as quick as it should be.
When towing my trailer (Maybe 3k ilbs or a little over) even the slightest incline the truck falls on it's face and I try and accelerate and just doesn't seem to speed up but the EGT's climb quick. As well as it shifts through the gears way too fast, which it always has since trans rebuild.
I got on it on then way home today to see where everything was at.
My EGT's climbed to 1,300* real quick and it pulled a whole 8-9lbs of boost and maybe hit 50mph.
Text my old mechanic, who put the 38r on and rebuilt the trans twice and he said it sounds like a possible speed sensor??
When people switch to the 38r, does anyone do anything to the exhaust side of the turbo? Sorry not sure what it's called but it's the exhaust side that is rusted.
Could high EGT's, low boost, low power be due to the EBPV stuck?
Could it be shifting through the gears too fast be due to speed sensor?
Thanks
Thanks
