Map sensor no boost
Bori813
First of all happy New Years I have a 2003 SD 6.0 had to change high oil pressure pump and the truck started right up but had no boost I unplug the map sensor and it will show boost 3 to 8 psi on my Edge chip what could be causing this problem
Sent from my SM-N910T using Tapatalk
Bori813
Here's a pic of the codes that came on
ghohouston
Lewisville,Texas
Have you checked the rubber hose that goes from the map sensor to the intake manifold AND poked through the nipple on the intake manifold to make sure its clear? The hose should fit tight at both ends and have no rips or tears. I would also blow through it to make sure there is no carbon buildup inside.
Bori813
Yep it had a cut on the hose I changed the holes and checked the intake manifold nipple stuck a hanger in it was clean
Bori813
I checked the vgt wires they look good
Bori813
Could it be vgt sensor how can I check that
Mesa, AZ
To check the solenoid, you have to have a way to command it. You remove it, put your thumb slightly depressing the plunger, and when you activate it it will vibrate. The solenoids dont typically go bad though. Have you verified that the turbo is actually spinning? I chased my tail on one that had a siezed turbo, because the center housing was fairly new. I forgot the kiss method. :doh:
Bori813
OK thanks I'll give it a look
Mesa, AZ
Try pumping 15-20 psi of regulated air into the map sensor with it plugged in, see if it changes. Could have a bad sensor. Dont put more than 20psi into it, you could damage it with unregulated 120+ psi of air
Bori813
OK I'll try that next thanks for the quick reply
Bori813
That's what I get when truck is on idle
Bori813
But I get no boost everything else works great
Bori813
Yep and changed the sensor same thing turbo is spinning too
Mesa, AZ
Hmmm.... chit, i missed your ebp reading in the picture the first time. Do you know if that is ebpa or ebpg? Nevermind, saw its an 03. Is the ebp plugged in?
