F-250-Owner
Soo a few weeks ago my rearend went out...completely out. So I swapped it out no problem...3 days later the tranny **** the bed so in went a good used tranny and torque converter....then a week later..the head gaskets finally let go and it was time to replace them. I had a set of 20mm oem gaskets here but didn't have any 20mm heads in stock...so what did I do? I had the 18s machined to accpet the 20mm dowels and away we went. Everything went as planned but while it was down I had a set of 155 stock nozzle injectors built from cores that I had here...engine would run...but wouldn't restart hot...changed everything in the high pressure oil system only to find that the injector tops were trashed...swapped them out yesterday and it now runs like a champ again...... sorry for the long story but I'm just relieved that its done......for now
Sent from my SPH-L710 using Tapatalk 2
