My s475 winter project
Bushwood_6.0
St Mary's county, Maryland
Im running RCD 285/150 hybrids and my s472 doesnt begin to clean up the injectors. It also lights fairly quick and is definitely streetable with my 2800 stall converter
Yea I think I'm starting to lean towards 285s with my stock bottom end them when and if I build it jut send them out and made bigger for spray.
STROKER
How does it act when it's lock in over drive cruising and just normal driving manors
Hot and laggy in overdrive LOL. Normal driving its not bad at all though. I would highly suggest getting your injectors from RCD or MPD they are not something you wanna cheap out on.
Josh@DirtyDiesels
PA
I run a s475 and MPD 300/150 conventionals. Losing big power without dual hpops. Doesn't even come close to holding icp. I also run a 2000 stall PI converter. Spools perfectly fine on the street and can be driven pretty smoke free if you don't drive like a dick. I'd go smaller on the injectors and stay conventionals unless you plan on dual hpops. Even with low icp and at the power level mine is at now it's still a blast to drive
Josh@DirtyDiesels
PA
Oh, and another +1 for MPD injectors. Buddy of mine had a set of 380 warren hybrids, swapped to a set of MPD injectors identical to mine and picked up 100hp... jusssssayinnn
Bushwood_6.0
I've been following your build and hope you figure out your dual pumps I know it's gotta be frustrating. And how does it do building boost for a launch.
Hopefully it can be ready by dirty diesel dyno event
Josh@DirtyDiesels
PA
Builds boost fine to launch it. Just have to be easy on the pedal. Can't just mash it to the floor or it takes a bit longer to spool with the 2000 stall converter. It honestly does spool really nice. Feel free to PM me on here or shoot me a message on FB if you're on there and you know who I am lol
Bushwood_6.0
Thanks man will do.
stroker57
frostburg,MD
FWIW I have warrens dual pumps and hybrid injectors put about 1000 miles on so far with no problems and no dilution
