Need new battery terminal
n54power
As you know the stock positive terminals tend to wear out.I'm trying to find a aftermarket terminal that will accommodate the factory large power wire,aux wires for lights and power cable for an amp.
this would be for the drivers side. Who/what have you guys used and how did it work.
On the passenger side the main powER cable has a battry terminal in the middlr of the line.
It's worn out and needs to be replaced. I've thought about cutting out the terminal and using a aftermarket piece that would work. Maybe with an extra couple spots for a large powe wire I could run to the back for auxiliary backup lights
Suggestions
