New RS kit is now available!
OBSWIZ
Wellington NV
Its taking a few years to get the new revised RS kit designed but its out..this is the best way to get a great ride quality from your OBS truck..add the new RS kit with SD V and B codes. higher lifts are available to 11"
The rear shackle hanger is relocated to get the shackle angle correct and the new front mount no longer requires the bumper to be cut. Its designed to use SD springs now so no additional work is required. The drop track bar bracket is designed with the correct offset for use with the SD springs
Please PM for more details and costs, Its on sale!:
Strokersace
Towanda, KS
What is the minimum amount of lift with the new RS kit? Also, what tire size can you run with the minimum?
Pics look good.
Strokersace
Towanda, KS
Using stock springs it will add 3"
Using SD springs V and B codes with a 4" rear block will be level.
I assume it'd be the same with V code SD springs?
Looking for options for the future for an OBS F350 w/ current 6" lift. Want it to come down considerably.
