New stereo, need different ignition source
Jerrybizzle
Meridian, Idaho
So over the weekend installed a new deck and sub. I think my wiring harness is bad or had a few wires swapped. Plugged it all in and it didn't work, ugh, eventually hooked deck directly to battery and it turned on so knew it was a wiring issue. Bypassed harness with power wire as it wasn't working and now it works. Well the issue I'm having is the yellow (ignition) wire is getting constant power vs keyed (ignition on) power. I have to manually turn deck off and on. Does anyone know which wire is the ignition wire to the factory harness? Or which wire/fuse should I tap in to for a keyed/ignition source?
I went with a jvc 230bt DVD head unit. I have an xl so didn't have Bluetooth or sync. Paid $170 for the 220 (factory refurb) and they sent the 230, so I scored. It's about 270 anywhere else I can find it.
Alpine 600 watt rms amp pushing a classic Rockford fosgate punch hx2 12. Put the sub directly behind center console with some 2 inch risers and firing the sub down. I have kids and dogs so did not want it pointing up.
Wired backup camera to upfitter switch 2 which is working great.
Zmann
scroll down to red
and note they did not have a 2012 but the 2011 and 2013 seem to be the same so ..
2011 Ford F250 DirectWire 2.0 Vehicle Information
Item Wire Color Polarity Wire Location
12 Volts red (125A) + battery or BCM, black 1 pin plug (G), pin 1
The BCM (Body Control Module) is the fuse box in the passenger kick.
Second 12 Volts GREEN/ red or blue/red (15A) + ignition switch, 7 pin plug, pin 4
Starter blue/white + ignition switch, 7 pin plug, pin 7
Second Starter N/A
Ignition WHITE/ orange + ignition switch, 7 pin plug, pin 1
Second Ignition N/A
Third Ignition N/A
Accessory PURPLE / green + ignition switch, 7 pin plug, pin 6
Second Accessory N/A
Third Accessory N/A
Keysense blue/gray + ignition switch, 7 pin plug, pin 5
Data Bus yellow/orange (TX), PURPLE / gray (RX) data PATS Transceiver, black 4 pin plug, pins 3 and 4
The PATS (Passive Anti-Theft System) Transceiver is around the ignition switch. The PATS ignition wire is PURPLE / orange in pin 1, and ground wire is BLACK/ gray or BLACK / YELLOW in pin 2.
Can Bus High gray/orange (medium speed CAN) data data link connector, black 16 pin plug, pin 3
Can Bus Low PURPLE / orange (medium speed CAN) data data link connector, black 16 pin plug, pin 11
Can Bus Sw N/A
Power Lock blue/green - driver kick or BCM, black 26 pin plug (C), pin 6
Power Unlock yellow/purple - driver kick or BCM, black 26 pin plug (C), pin 8
Lock Motor gray/brown 5 wire driver kick or BCM, 32 pin plug (D), pin 26
Driver Unlock Motor blue/green 5 wire driver kick or BCM, 32 pin plug (D), pin 21
Passenger Unlock Motor PURPLE / gray 5 wire passenger kick or BCM, 32 pin plug (D), pin 31
Parking Lights (-) yellow/orange - headlight switch, gray 10 pin plug, pin 2
May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ gray or BLACK / YELLOW at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Parking Lights (+) yellow/blue + BCM, 10 pin plug (E), pin 6
Hazards BROWN / yellow - BCM, black 52 pin plug (B), pin 32
Turn Signal (Left) blue/green (F); gray/brown (R) + BCM, green 26 pin plug (F), pin 8; 32 pin plug (D), pin 12
Turn Signal (Right) yellow/purple (F); PURPLE / orange (R) + BCM, green 26 pin plug (F), pin 7; 32 pin plug (D), pin 15
Headlight yellow/blue - headlight switch, gray 10 pin plug, pin 7
AutoLights PURPLE / green (interrupt to turn off autolights) - headlight switch, gray 10 pin plug, pin 4
Reverse Light blue/white + BCM, 32 pin plug (D), pin 13
Left Front Door Trigger GREEN/ purple - N.C. passenger kick or BCM, black 26 pin plug (C), pin 9
Right Front Door Trigger white - N.C. passenger kick or BCM, black 26 pin plg (C), pin 5
Left Rear Door Trigger green - N.C. passenger kick or BCM, blk 26 pin plug (C), pin 20
Right Rear Door Trigger yellow - N.C. passenger kick or BCM, blk 26 pin plug (C), pin 21
Dome Supervision gray/purple (dome lamp); purple (puddle lamp) + BCM, 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1
Trunk/Hatch Pin N/A
Rear Glass Pin N/A
Hood Pin blue/orange - N.C. BCM, green 26 pin plug (F), pin 2
Trunk/Hatch Release N/A
Trunk Release Motor N/A
Fuel Door Release N/A
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock Transponder, ignition, and accessory
See Tech Doc 1098 for wiring information.
Trunk Alarm Shunt N/A
Tachometer blue ac Customer Access Harness
The Customer Access Harness is above the driver kick, taped to a wiring harness. On vehicles without the Customer Access Harness, go to any fuel injector and use the wire that is not blue (gasoline), or use the camshaft position sensor, which is WHITE/ green at the PCM, middle, black 98 pin plug, pin 32 (diesel). The PCM (Powertrain Control Module) is on the passenger side of the engine.
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal black (in), blue/orange or PURPLE / blue (out) - N.O. clutch switch, gray 6 pin plug, pins 2 and 1
Fuel Pump yellow/purple (gasoline) - BCM, green 26 pin plug (F), pin 6
The BCM (Body Control Module) is the fuse box in the passenger kick. On diesel models, use BROWN / white (+) at the Inertia Fuel Shutoff Switch above the passenger kick, gray 3 pin plug, pin 1.
Rear Defroster WHITE/ orange - latched HVAC Module, gray 32 pin plug, pin 25
Mirror Defroster same as rear defroster
Left Front Heated Seat (CAN bus)
Right Front Heated Seat (CAN bus)
Speed Sense PURPLE / orange ac Customer Access Harness
Brake Wire PURPLE / white + brake switch or BCM, black 52 pin plug (B), pin 28
Parking Brake WHITE/ purple - Customer Access Harness
Horn Trigger PURPLE / green - horn switch or BCM, black 52 pin plug (B), pin 33
Wipers (LIN bus)
Left Front Window (Up/Down) blue/gray - yellow/purple A master window switch, 8 pin plug, pins 5 and 1
Right Front Window (Up/Down) BROWN / yellow - GREEN/ orange A driver kick, door harness
Left Rear Window (Up/Down) blue/orange - yellow A driver kick, door harness
Right Rear Window (Up/Down) gray/purple - BROWN / green A driver kick, door harness
The power sliding rear window open/close wires are PURPLE / brown - yellow/orange (5 wire) at the overhead console switch, 12 pin plug, pins 4 and 9.
Sun Roof (Open/Close) pur/brn - yel/org (function with ignition on only) - overhead console switch, 12 pin plug, pins 6 and 8
Sun Roof (Limit/Close) N/A
Memory Seat 1 PURPLE / white - driver kick, door harness
Memory Seat 2 yellow - driver kick, door harness
Memory Seat 3 N/A
Radio 12V gray/red + radio, gray 24 pin plug, pin 1
Radio Ground BLACK/ blue or black - radio, gray 24 pin plug, pin 13
Radio Ignition gray/blue (except navigation) + radio, gray 24 pin plug, pin 2
Radio Illumination PURPLE / gray (dimmer) + radio, gray 24 pin plug, pin 3
Factory Amp Turn-on PURPLE / red (sub amp); brown (audio amp) + radio, gray 8 pin plug, pin 4; gray 24 pin plug, pin 7
Power Antenna N/A
Left Front Speaker (+/-) white - WHITE/ brown +,- radio, gray 24 pin plug, pins 8 and 21
If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are white - WHITE/ brown at the audio amplifier, black 8 pin plug, pins 4 and 8.
Right Front Speaker (+/-) WHITE/ purple - WHITE/ orange +,- radio, gray 24 pin plug, pins 11 and 12
If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange at the audio amplifier, black 8 pin plug, pins 6 and 2.
Left Rear Speaker (+/-) WHITE/ green - BROWN / yellow +,- radio, gray 24 pin plug, pins 9 and 22
If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are WHITE/ green - BROWN / yellow at the audio amplifier, black 8 pin plug, pins 7 and 3.
Right Rear Speaker (+/-) BROWN / white - BROWN / blue +,- radio, gray 24 pin plug, pins 10 and 23
If equipped, the audio amplifier is under the driver dash. On vehicles with amplifier, the speaker wires are BROWN / white - BROWN / blue at the audio amplifier, black 8 pin plug, pins 5 and 1.
Center Channel (+/-) N/A
Subwoofer (+/-) PURPLE / green - GREEN / WHITE +,- radio, gray 8 pin plug, pins 1 and 2
Aux. Audio Input Left (+/-) blue - YELLOW /GREEN (without SYNC) +,- radio, gray 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-) blue/green - WHITE/ green (without SYNC) +,- radio, gray 16 pin plug, pins 6 and 14
RSE Video (+/-) WHITE/ green - BROWN / purple (rear camera video) +,- radio, gray 10 pin plug, pins 1 and 6
RSE Audio Left (+/-) grn/org - blu/brn or blu - gry/og (sat/SYNC audio) +,- radio, gray 16 pin plug, pins 1 and 2
RSE Audio Right (+/-) pur/brn-yel/blu or pur/grn-brn/wh (sat/SYNC audio) +,- radio, gray 16 pin plug, pins 9 and 10
Satellite Radio 12 Volts PURPLE / red + Satellite Receiver, black 12 pin plug, pin 9
If equipped, the Satellite Receiver is under the driver dash.
Satellite Radio Ground BLACK/ blue or black - Satellite Receiver, black 12 pin plug, pin 3
Satellite Radio Ignition (CAN bus)
Satellite Radio Antenna (coaxial cable)
Satellite Audio Left (+/-) GREEN/ orange - blue/brown +,- Satellite Receiver, blk 12 pin plug, pins 5 and 11
Satellite Audio Right (+/-) PURPLE / brown - yellow/blue +,- Satellite Receiver, blk 12 pin plug, pins 6 and 12
Item Size Depth Location
Headunit double DIN center of dash
Left Front Speaker 6 x 8 left front door
Left Front Tweeter left front door
Right Front Speaker 6 x 8 right front door
Right Front Tweeter right front door
Left Rear Speaker 6 x 8 left rear door or left rear pillar
Left Rear Tweeter left rear door
Right Rear Speaker 6 x 8 right rear door or right rear pillar
Right Rear Tweeter right rear door
Center Channel N/A
Subwoofer under or behind rear seat
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner (built into radio on some models) under driver dash
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Interface Modules
SKU Module Description Upgradeable Keys Required for Programming Keys Required for Operation
