New to obs
Dirtclod
Pilot Mtn. NC
Ok I found a 96 f250 ext cab long bed for 6500$ 335000 miles 4x4. I've also found a 90 f350 cab chassis with blown 7.3. Was wondering if the rear end will work in the 96 and the 5 speed manual fit in the 96. Of course I would have to change front diff gear to match
97powerstroke
Fleetwood Pa
The transmission will fit but the rear axle will not. I'm not sure on the torque ratings on the early 5 speeds so you might want to look into that.
79jasper
skiatook, Oklahoma
Torque is basically the same. The trans will work fine.
The rear end won't. Chassis cab has a narrower axle. It's not a direct swap.
Dirtclod
Pilot Mtn. NC
Yep I didn't think about it being chassis cab. But with some fabrication it could work but not worth it. The guy only wants 1500 for the 90 model and it comes with a nice flatbed. He said there was a hole in the block.
