I have them, (295/70/r18s) I will not get them again. I have around 30k on them and they are toast. after half tread they seem to loose all their grip. I rotated them every other oil change so around every 8k miles. it also seems like to get proper tread wear u constantly have to adjust tire pressure if you tow something as if u bump the pressure up u will wear out the centers too fast. I run 68psi in the frt and 62 in the rear and used the chalk test to set the pressure
my next set of tires will be toyo open country AT II.
edit... im sorry, I thought the title said terra grappler, and that's what I have
