No Limit Venturi Placement
WHY NOT
Carlyle IL
Where are you all putting your venture's in your exhaust? I have a guy coming that can help me weld up the stainless here in a bit and was wondering where everyone is putting them and how they are running the hose from the CCV to them, also can the hose ever go up wards or does it need to be at a constant slope downwards as to not clog with oil?
Last question is it 5/8" heater hose that I need since I will need to get more to run it. Right now I have it ran down the drivers side by the steering and it dumps right after the trans cross member.
ncollins64
winchester springs, tn
Pic
For everyone else, it's welded in the last section before the over the axle piece. My canister is mounted on the outside of the frame by the t case skid plate and then the hose is routed over my tank and down to the ex.
BIG JUICE
Valrico FLA
got pic of canister location? just installed dieselsite fuel filter in location I think you are referring to
