no power to cab.
vinniehobart
Just replaced my oil cooler through in a t4 mount turbo and did injectors. I got everything back in and hooked batteries up. went to turn the key and nothing on dash came on. where do i check to see if im getting power to the cab?
Gary
South Lyon Mi
Check the positive battery cable on the drivers side battery, look at the wire that that connects to it. See if there is a bad connection, if that is good then check the rest of the cables.
