drservo
- Joined
- Sep 30, 2011
- Messages
- 410
- Reaction score
- 0
No worries, I didnt take it as though you were knocking our bars.
I like Lucas Red Tacky, but you do have to keep an eye on it in dryer climates as it can dry out. Another good one I just found was Valvoline Cerulean.
The large 3.0" joint at the front side of the bars should be tightened down just to the point that you can still move the ball around by hand but feel a reasonable amount of friction on it. All of the smaller poly bushing location bolts and frame bolts should be torqued to 110 ft lbs.
The front shackle should sit perpendicular with the frame of the truck while the truck is unloaded and sitting on level ground. The 3/4" bolt that holds the traction bar into place should slide into the hanging shackle freely with out any preload on the bars.
I would suggest doing one change at a time, this way if it fixes the problem, you have isolated it. Doing a bunch of things all at once may fix the problem but it wont tell you the true source of it.
If you need anything, just let me know.
I know the ball does not move freely by hand, so I need to loosen the bushing nut?
I have to bump the 3/4 bolt out with a mallet, do I loosen the jam nuts and back off on the threads at the back of the bars?
