Detailed Vehicle Specification
VIN 1FTNW21F92EA12253 Vehicle Line T/F7 Market Derived Code F Body Cab T/BC Ver. Series T/BD Drive Type T/E PLT CD A1 TRS CD T/D8 ENG CD T/DS Production Date 02-AUG-01 Warranty Start Date 25-OCT-01 Selling Dealer 152080 Selling Country USA
AWS Claim Key Trx Code Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc
Details 10247992 E72 31 3 ANCIRA FORD 70384 11-MAY-04 F81Z 9E436 AA 11852901
Customer Comments C S VEHICLE HAS OIL LEAK.
Tech Comments INSPECTED. ENGINE OIL LEAK WITH LEAK DYE AND BLACK LIGHT. FOUND OIL LEAK COMIN FROM HIGH PRESSURE OIL PLUG ON RT SIDE REPLACED LOWRE O RINGS AND TURBO INLET TUBE O RING. REPLACED RIGHT SIDE O RING TO HIGH PRESSURE OIL PLUG O RING. VERIFIED
Details 17086738 07S57 86 .3 ANCIRA FORD 145616 11-NOV-08 * * * 15801003
Customer Comments RECALL 07S57
Tech Comments REPLACED CAM SHAFT POSITION SENSOR
Details 17399923 09S09 99 .2 ANCIRA FORD 167468 16-NOV-09 * * * 16569003
Customer Comments RECALL 09S09.SPEED CONTROL DEACT.SWITCH RECALL.
Tech Comments RECALL COMPLETE.INSTALLED SPEED CONTROL DEACT.SWITCH.
Details 18823623 SPW 139 .7 ANCIRA FORD 209933 04-MAR-13 BXT 65 750 18957902
Customer Comments CUSTOMER STATES CHARGING SYSTEM IS LOW AND NEEDED TO JUMP START THE TRUCK
Tech Comments PERFORMED CHARGING SYSTEM TEST AND BATTERY LOAD TEST. DTCS 026MA FCTJ0 182 ACES XG48S DTCS 038JS WJTN4 368 ACES XE58S SPW RO 175507 4-01-1 REPLACED BOTH FAILED BATTERIES RETESTED AND VEHICLE CK OUT FINE.VERIFIED REPAIRS
