Jkk7_3
1 set of stock injectors all 8 $400
Stock turbo no shaft play $150
Gray ext cab door panels $50
T4i mount up pipes oil line downpipe intake pipe and IC pipes $400
1 set of loaded heads both passenger and driver side $200
Windshield cowl body panel $50
AC compressor $50
Grille $30
Ext cab rear bench seat whole set $50
AC condenser $50
Radiator $50
Clutch fork for zf5 $20
Inspection cover $40
Brake booster with master cylinder $50
4wd linkage $200
Gas pedal with no sensors $20
Intake boots and pipes $10 each
Stock intake box $20
Fuel bowl $50
Stock lift pump $50
And much more. Comment what you need
Will ship or meet locally
AC compressor $50
Grille $30
AC condenser $50
Radiator $50
4wd linkage $200
Fuel bowl $50
Stock lift pump $50
