Pstrke96
So I like to think I'm pretty inclined mechanically. I am a diehard 7.3 guy and I have owned 3 personally and fam has had about 15 more. that being said I've changed a lot of rotella with Lucas stabilizer in it over ten years. I did a change on my stock 02 5000 miles ago 1 gal Lucas 11 quarts rotella 15-40 Dino .
On first start after change it loped ridiculous and had zero power . I called a ford diesel tech friend and we agreed Lucas made it to thick and once it thinned out all would/should be better. We'll now 5,000 miles later half of which towing a 16k fw tt it still lopes like crazy on first start of day. It will lope for 30 seconds or so then stall if started normally. If I stab the throttle it will smooth out and be great rest of the day. There's no smoke, temp makes no difference, no cel, I'm stumped also it seems to take about 6-8 mins at idle or stuff it down the street to get ebpv to open and let truck perform normally. Also changed GPR on same day as oil in February. I plan tomorrow to change hpo res oil and add about a quart of sea foam unless I get some advice tonight thanks in advance guys.... Gary
