sickslow
- Joined
- Jul 29, 2011
- Messages
- 215
- Reaction score
- 0
I am trying to decide if I should go in for an oil cooler or not. The reason that I am trying to decide right now is because I just got a coolant filter and an egr delete and I know after I put these on the chances of getting the oil cooler replaced under warranty is slim. I wish i could run the coolant filter for awhile before a new oil cooler so that the new one has no chance of clogging but I want to get this egr delete on as soon as possible so its either all of it now or get a new cooler (if they will warranty it) then put on the parts.
My temps cruising around 55mph are only about a 9 degree spread. When Im running around 75mph the temps will fluctuate from 13 to 16 degrees different (EOT>ECT). The one thing that confuses me about this is that the oil never gets hot so it seems odd to get a new cooler. An average interstate reading would be ECT 180 EOT 194.....so the spread is 14 but its still pretty cool....maybe my thermostat is sticking a little? The faster average speed im running the greater the spread. When in town with the occasional red lights I only see about a 7 degree spread. I know one of the main concern of a clogging oil cooler is that it starves the EGR cooler of coolant causing it to rupture. According to that wouldnt it be ok to delete the EGR (removing cooler failure risk) and leave this cooler in? Is it wishful thinking to get rid of that risk and bet on the coolant filter keeping the oil cooler at its current state for a couple more years? I plan on doing studs this summer or next summer and I would replace the cooler then on my own dime but by that point the filter would have the coolant passages in much better shape.......If only ford would see that im trying to help my truck and not hurt it....lol
Also what is the chance that if I took it in to the dealership that they would replace the cooler. Sometimes it takes 15 minutes of time cruising the interstate to reach close to a 15 degree gap and usually it will hit 15 and fall back to 14 or 13 within a minute. I don't want them to say some dealership bs like "your monitor is not as accurate as your factory temp gauge and as long as its not hot your fine" I think we all know here that the factory gauge is useless.
Any advice would be greatly appreciated. Thanks
