Oil cooler replacement
Eastern Shore Of Maryland
So I'll be changing my oil cooler here soon as my deltas are about 25*. I also plan on egr delete and newer turbo while I'm at it. My question is, what else should I replace or do while it's apart? I already have the upgraded standpipes and oil fittings. And the egr delete will have the intake gasket and the up pipe replacement. I'm gonna go with an 03 turbo or a pmax with plans of a 366 t4 in the future. Any ideas or suggestions will help. Also gonna dump CCv In atmo.
mcdaniel1991
Germany
Keeps the coolant out of the manifold, lets the cooler flow much better.
Sent from my GT-I9305 using Tapatalk
mcdaniel1991
Germany
Get in touch with Steve on here (Powerstroked162) and he can hook you up.
william_ace
I would do a ported intake manifold. There are plenty of options out there if you do a search.
andyjman
lower egt's better air flow, faster throttle response. I got one of odawg's on my truck and it was noticible the second I took it for a drive.
