Oil light on for 1 second after startup
Mike_D
Northern, CA
Lately I have noticed that after letting my truck sit for around a week without being started, on initial startup I'll see the low oil pressure indicator in the information center of the cluster.
It goes out within a second of the truck running. After driving the truck and restarting, it does not show up again. Even if I drive it a day or two later, it typically will not show up. Only after a long sit.
Any ideas? Thinking maybe the oil drain back could be the culprit. Maybe the oil pressure sensor?
I am running a Motorcraft filter with Delo 15w40 oil. Ambient low temps have been maybe 50* here.
Thanks guys
Mike_D
Northern, CA
I'll check that out. If it sits for a week or so, when I pull the oil filter it should still be pretty wet correct?
Mike_D
Northern, CA
It looks like the 6.4 and 6.0s use the same PN: 3C3Z6C755AA
Probably going to replace the entire stand pipe vs trying to just change the anti drain back valve at the bottom.
