P0232
extreme3807
Bucyrus, OH
Has anyone had a P0232 high voltage fuel pump secondary circuit code? If so what caused it and how did you fix it?
webb06
Seneca, MO
Pretty sure I had this code. If the airdog or whatever your lift pump is isn't hooked to the factory power supply for the stock lift pump you get this code. Mine did it right after I got my build done. Started fine the first and second time then wouldn't start. Rewired the airdog using the factory power supply and wabam it works great. Might check that out.
extreme3807
Bucyrus, OH
Yeah my AD is just going to the fuse box in the engine bay, I'll require it into the factory pump line tomorrow, thanks
91turbogsx
Gardner MA
I have my AD wired off the fuse box with zero issues or codes related to it. I'm just curious why I haven't had that issue but you guys have?
Hope it solves your problem Nick.
webb06
Seneca, MO
No clue but I've researched and found several issues with it. And wiring to the factory harness fixed the problem
