1FastGambler
- Joined
- Apr 23, 2016
- Messages
- 12
- Reaction score
- 0
Hello everyone, I just upgraded to an Elite trans, DPC converter, AFE intercooler, RCD 73 mm atmo & 59mm VCT turbos, & No Limit CAI.
I keep getting P2263 code and CEL.
Watching the dashdaq I'm seeing between 20 and 40 psi variance between boost pressure and exhaust back pressure.
So, It appears that this code is popping up due to the max variance.
The 73mm was installed first and ran for a couple days prior to installing the 59 mm VCT. While just the VCT was installed the spool up was slow and I noticed the boost gauge would climb slower than with stock turbos.
I'm not sure if there is something wrong with the new RCD 73mm or what to look for to resolve this issue.
Where should I start looking?
I've checked for boost leaks - none.
I'll run it again and get a log and see what the data actually shows later today or tomorrow.
