P2263 & P132B
BSalisbury
Looking for opinions on borg Warner turbo actuator upgrade kit! I lost all boost and throwing p2263 & p132b codes! Checked EBP sensor and tube both are clean but got new one otw! Only other though is turbo actuator and I’m looking at the borg Warner upgrade kit that does away with the cooler! Any help much appreciated! Thanks 08 early build F250
DEEZUZ
NO PUKESTERS
NWI
Comparing pids helps alot. Watch MAP MGP EBP BARO KOEO, compare them, then what do they read at idle, then under load. Etc.
Does the actuator bounce back good when pulled forward?
BSalisbury
Had to work all weekend! Haven’t gotten back to it yet. I did pull the ebp sensor and tube all looked clean.
ghohouston
Lewisville,Texas
Check your c.a.c. boots for tears. Iirc, I had a guy with these codes and it ended up being a pretty good boost leak on the lower c.a.c. hose on the intercooler. You could hear it at idle.
