Parting out 96 F350 CCLB 4x4 PSD
superduty4x4
Newport, WA
I'll probably know more as I get into it further, but I figured I may as well get a post up.
AC condensor $50
Brake master cylinder $30
Brake booster $30
Alternator $50
Vacuum pump $30
Degas bottle (1 mounting tab broken but the bottle itself appears ok) $10
Underhood fuse box/wiring SALE PENDING
CA emissions PCM, calibration code MIF6 $150
Dash assembly- no gauges, bezel, wiring, or dash pad SOLD
Aluminum brace for the dash on the driver's side $20
Throttle pedal assembly (may keep as a spare) $150
Interior plastic trim pieces - make offer
Door panels (would like to sell as a set if possible) SOLD
Window motors SOLD
Door lock actuators SOLD
Door glass- all except driver's side front $30 each
Wing window assemblies SOLD
Rear bench seat $200
Rear sliding window $100
Interior cab lights SOLD
3rd brake light $10
Rear end- brakes good, 4.10LS $250
Rear springs $100
Passenger rear door $250
8' bed- damage on driver's side only, not sure if it would be worth having a new bed side welded on or not. Make offer
If it's not mentioned above its either sold, no good, or something I want to keep but feel free to ask if there's something you're after. Prices are OBO, shipping will be actual cost.
swamp_ratt
hudson, wi
Dibs on door panels, wondow motors, door lock actuators, and xlt wiring harness for the door locks and windows
superduty4x4
Newport, WA
More stuff...
AC compressor SOLD
Stock OBS turbo/pedestal $300
Good AB injectors SOLD
Long block $1000
Reman 15° HPOP SOLD
Right tail light $20
Steering shaft (between column and box) $40
Front and rear fuel tanks $100 each
Selector valve $30
swamp_ratt
hudson, wi
The third brake light harness is part of the harness i have dibs on.
If iirc when i talked to him on the phone last night hes in washington state
superduty4x4
Newport, WA
Front drive shaft?
For now, I'm keeping the auto trans and everything needed to convert from a 5 speed to an auto just in case I decide I don't like rowing gears.
location?
North east WA state, right on the ID line.
Dibs on the dome lights
I had someone else ask about them, if he bails they are yours.
How about the third brake wiring harnes and lens? And the fuel filler necks?
Third brake light lens I had listed for $10, I'd like to keep the fuel filler necks with the tanks but shoot me an offer and maybe I'll change my mind.
Door panels, window motors, lock actuators, and all the wiring is sold, thanks swamp_ratt!
PsRumors
Cartersville, GA
I don't really need the lens was just throwing it out there for the 6" harness that comes with it. If that piece of the harness is gone the lens is worthless to me.
The offer for the filler necks probably isn't worth it if you want to keep them together.
Maybe next time. :)
swamp_ratt
hudson, wi
Really? Where does that fall into your "dibs" request?
Its part of thr cab harness. I will send you mine off my truck for just shipping price if you want. Lens aint to good though, not broken but not too clean. I am buyin his whole setup for cab wiring just to replace mine. Mine is an xl
PsRumors
Cartersville, GA
I just need from the plug to the lens, don't even need the lens. If the bulb sockets (all 3), wire and plug is all in good shape I will gladly buy it from you.
Chimera
Astoria, Oregon
ok, if you decided to sell it text me, Craig is looking for a trans harness. hes got a short in his somewhere and it'll randomly pop a 15amp fuse
