Phoenix Gold SD800.5 5 Channel Audio Amplifier
MPTonyT
Tampa Bay, FL
This little amp is perfect to power all four doors and single woofer. This amp was used in a coworkers vehicle for about 1.5 months and she decided to go a different route. This amp was brand new when I installed it into her vehicle. It works perfect and looks like new. The smoked plexi glass top does not have a scratch on it, that is a piece of hair on it.
Looking to get 150.00 shipped to your door (Lower 48) and ill ship anywhere else for the price of shipping.
Any questions feel free to ask. Text or message 772-201-7380
I also have a pair of Phoenix Gold R-Series 5x7's and a Phoenix Gold R310D4 woofer that is in an underseat F150 box that I'm looking to sell.
Specs:
POWER RATING
125 Watts x 4 Channel / 2 Ohm
75 Watts x 4 Channel / 4 Ohm
300 watts x 1 Channel / 2 Ohm
200 watts x 1 Channel / 4 Ohm
LOW PASS RANGE
30Hz to 300Hz
LOW PASS SLOPE
24dB/Octave
HIGH PASS RANGE
15Hz to 300Hz
HIGH PASS SLOPE
12dB/Octave
POWER TERMINAL
4GA
FREQUENCY RESPONSE
20Hz to 20kHz (+/- 1dB)
SIGNAL TO NOISE RATIO
Greater than 100dB
HARMONIC DISTORTION
Less than .1%
EFFICIENCY
70%
DAMPING FACTOR
Greater than 200
HEATSINK THERMAL MASS
5.0 grams per mm
DIMENSIONS
12.1" L x 6.9" W x 2.0" H
Link to the manual:
http://phoenixgold.com/images/manuals/sd_amp_manual.pdf
