php hydo chp question
turbocoupe
when removing the hydro chip does it have to set to stock position before removal?
not sure if the pcm will hold a tune on it or if its all in the chip
I want the pcm to go back to stock calibration
thanks
heavydoc
Cruso, NC
I believe it's all in the chip. Unplug it it should be stock.
Sent from my SM-N920V using Tapatalk
superpsd
Missouri
Yup pull the chip no more tune. Putting hydra in the 00 position also bypasses the chip.
Justin@DP-Tuner
As stated, pulling any chip off the PCM will put you back to the PCM calibration. Chips just override the PCM, so any time one is removed it does not leave any footprint.
