Big Bore
Stock pump blew the snap ring off the back and my attempt to push everything back in and run the pump was unsuccessful. Decided to put the Terminators back in without the dual IPR setup since I didn't have time to mess with any possible issues. I can hardly tell the difference between the stock pump and the Terminators using the same tunes. Sometimes the idle takes a second to settle and on startup idle is a bit noisy initially, but other than that I have not noticed anything other than it seems to pull harder and smoother up top, which makes sense with a stroked stage II single shot injector. The twins definitely do not exhibit any of the issues I had previously with tunes that were written specifically for the twin pumps by someone who had live tuned the truck at least twice. I have always suspected that there is no need for "special" tuning for them, and I also suspect that the twin IPR's will alleviate the idle issues since they will relieve the ICP much quicker.
Nice work on the tunes Curtis, as always.
