Halvy85
Had my RCD t/c, and imput shaft put in a few weeks ago and ever since then the transmission has been acting up. Almost like the rev slam issue these things sometimes have only 10x worse. Happens most around 15-20 mph driving around town if i let off the throttle and coast for a little bit when i go to speed up engine revs like its in neutral then slams into gear. Has happend a few times at higher speeds but usually not once the t/c is locked. I also noticed on the way to work tonight that after going through a 35 mph zone i got into the throttle about 3/4 and t/c didnt lock until around 60-65. Ive had my truck set on the 275EL tune from spartan for months. Any idea's or things i can try to fix this would be greatly appreciated.
