Newstroker
- Joined
- May 6, 2012
- Messages
- 57
- Reaction score
- 0
Like the title says, I am looking to sell my badass project to pursue an amazing business opportunity. Here is a short list of what is done to the car. I will continue to add to it as I have more time.
Full Chrome moly cage that should cert 8.50 - will need funny car cage for anything quicker
Backhalfed with fresh tin work – rear tires are 33X18.5 ET Streets
New Kirkey alum seats with covers new in package
Parachute mount
TRZ rack and pinion,
Moser fabricated housing with 40spline axles
Willwood brakes
Spool and third member with new 3.00 gears
4link with anti-roll
custom billet dash for autometer gauges.
Has factory steel cowl hood, bumpers, interior pieces, chrome etc.
12 Valve Cummins engine with around 160k or 190k
47rh trans with fresh build – Billet Input, billet servos, ATS 5 star conv, sonnax servo piston cover, aluminum accumulator piston, power wedge band anchor, 4.2 lever, performance rear band servo, and an SFI flexplate
Ratchet Shifter
Removable trans tunnel, shifter and switch panel
Autometer gauges –
Autometer 5” tach and shift light
63/68mm charger s300
Custom downpipe and intercooler piping
5x.014 Weston Injectors
7MM DVs
4K GSK
60# valve springs
Rack Plug
Adjustable Pump Gear
Fass 125 or 150LP – Need to check
New Fuel Cell
Two New Red Top Batteries
Car has fresh wiring for drag racing
New Brake lines
New Strange Master Cylinder
New Line Lock
New Proportioning Valve
New Relays and junction strips for wiring
New Aluminum Driveshaft
Custom Built Oil Pan for ground clearance
Custom Built Firewall and Motor Mounts
Brand New QA-1 Coil Overs Front and Back
Fresh Paint in engine bay and back half
Removable Steering Wheel
Tie Down Points Front and Back
Scaled on all four corners with initial suspension tune up
I will keep adding to the list
Car does need some things:
Fuel Lines need to be run
Trans cooler and lines
Brakes need to be filled and bled
Head studs, valve springs, GSK, rack plug, adjustable pump gear etc need to be installed.
Need to install coolant hoses
Engine and trans need fluid
Rear fenders need to be stretched or modified to give some additional clearance for the tires
The swap work and majority of the chassis work was done by a professional shop.
The only reason for even THINKING about selling this is a huge business opportunity fell into my lap this morning on the way into work. So, I can get some of my money back out of this car…great. If not, I will let it sit as I divert funds another direction.
Price - $25,000
Cell 61074137eleven
Location – Southeast Pa.
Might be interested in trades...never know. Also interested in triaxles...will def add cash for the right deal.
Parachute mount
Willwood brakes
Ratchet Shifter
Autometer gauges –
7MM DVs
4K GSK
60# valve springs
Rack Plug
New Fuel Cell
New Brake lines
New Line Lock
Price - $25,000
Cell 61074137eleven
