Coming from my experience with my twin turbo audi. This is always a big discussion on the audi forums " is there a difference in spool up from an aftermarket journal bearing borg warner, or a ball bearing tial/garrett/precision" . A lot of people tested it and there was a 2-300 rpm difference in similar sized turbos. My preference if I were putting a single turbo on, because that one turbo is experiencing all of the heat from the motor and pressure, and depending how much fuel you have and how hard thats pushing the turbo, Id want a ball bearing unit. They are proven to last longer and be more reliable.
If you took two turbos, one bullseye unit and one garrett, with their normal compressor wheels, with same exact size compressor/turbine wheels with same exact size A/Rs on the same motor, I cant imagine the difference in spool up would be more then a few hundred rpm, for the average joe it probably wouldnt even be noticeable.
