Radiator leak
mortal798
Michigan
I know this is an issue, but have any of you tried to re-crimp the core to the tank? I found a tool for this from Johnson Mfg, part number 414-01. Thought i'd give it a try before dropping $615 on a radiator from the dealer.
fat-fingered from my EPIC 4G
mortal798
Michigan
So, I ended up buying a replacement and installing it. Wasn't a bad job, but guess what??? The new one is leaking in the same exact place! Awesome!!! Way to go Ford finding a supplier who could consistently screw up a radiator 4 years in a row! :fustrate:
mortal798
Michigan
Talked to service manager at the dealer where I bought it, third radiator will be ordered first thing in the morning.
mortal798
Michigan
What is the tsb# and when did it come out? I need to go in for the bed plate leaking oil too, I actually got a drip from it now.
The rad is leaking from the rh lower corner between the tank and core.
