needs head gaskets, and two broken ex manifold bolts, both on #7.......has 98k........aside from the crossbow's, there really isn't anything performance oriented.
and even then, the crossbow's, after much talking and emailing various people, and conversing with Chad when i took my truck up there to pick his brain, aren't really a performance oriented set of chargers, when compared to others in its "category". there exactly what i was after. much better than stock, drops egt's, and realistically only gives up 20-30 hp over tow powers, and for what i use my truck for, i couldn't justify the additional $1300 for TP's. I'm not at a level to be able to justify that. that's a pretty tough pill to swallow even if you are at that level. not to mention simple availability of either set of chargers. and they should clean most of the race tune up, hopefully down to a slight haze.
that only leaves the cam, and even that is nothing to write home about. since it was going to be opened up, i wanted lifters and springs and prods. 98k, and i only really knew the history of about 14k of it. i decided on the cam, and had Chad spec something a little more tow oriented, than performance oriented.
with the head gasket job, and valve train, he was going to radius the valves and seats.
all this, as i only want to lift the cab one time, and since it was going up, i wanted to just freshen it up, as i kept my last one for 11 years and put 160k on it, and ill end up doing that with this one as well. with what i do, and how much i do it, i cannot afford to have it down more that one time. this truck moves everyday.
i feel that freshening it up, with the minor upgrades that I'm putting on it, there will be no sacrifice in reliability if in fact i didn't increase it, and i feel confident that this will last me the 10 years/150k i intend on keeping this truck, prolonging when it starts to feel tired, as i just took 98k off the clock. the 263k on my 7.3, while still a fabulous truck, you can tell its tired. i don't care what it is, short of a big rig, 263k is tired and in need of some freshening up.
the only thing I'm not attending to is the hpfp. on gearhead race tune, according to the livewire, I'm maintaining the 27,XXXpsi he is calling for. to me, that doesn't need replaced. when RP starts falling off, ill replace then.
trans and the rest of the drive train should still live a happy life, the motor and stuff added to it just makes it breath better, with some....fresh breath
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
im trying to get rcd to get me a set of manifolds and up-pipes, and ill have those installed as well when my truck goes up there. i just gotta call rcd, or maybe jared will pm me.
only thing left i want to do to it, is a icon leveling kit with 2.5's up front, and 2.0's in the back, and some pmf traction bars, and a set of bags in back so i can take my overload's off and smooth the ride out, and I'm done.
down the road, i will end up adding either 15% or 30% over nozzles and tuning the pw back. but i dont need to lift the cab for that. bigr's write up on head stud install cab on makes me confident of that. and i have alot of faith in matt for my tuning. he's just great at what he does, and will take the time to get it right, minor tweak after minor tweak if thats what it takes.
