BOHICA256
Okay guys so I'm wanting to remove the rear block. Any advice/how do you do it? It seems really simple so I'm trying to get it done this evening.
Use new u bolts also
What do I have to do to even to take it out?
Jack the truck up, remove the wheels, put it on jack stands. Get a jack under the axle. Unbolts the u bolts. Lower the axle, remove block, raise the axle, install u bolts. Repeat on the other side.
What do you mean by measure front to rear?
