Rear diff help
smokin99stroke
Orlando, FL
Sorry for the double post, I posted this in drivetrain forum but figured it would get more exposure here. I really need some opinions today so I can figure out what I need to do because I do need the truck, thanks guys
I'm changing the fluid in the diffs today and take off the rear cover to find this. What is causing this scarring and what should I do about it? The pinion seal is leaking slowly if that makes any difference. Any help would be great. Truck has 212k miles and I'm not sure of the rear diff service history
nwpastroker
Northewestern Pennsylvania
Drop your rear drive shaft and check the nut holding the pinion yoke on, looks like it could have loosened up and the pinion slid in, or a previous installer may not have properly tightened it and didnt crush the washer
Zmann
you better hope that is from a previous episode
I have seen worse but it is definitely from the pinion going to far into the carrier
and since gear lash is so critical if this is a current problem a major failure wouldn't be far behind
smokin99stroke
Orlando, FL
I have no way of knowing if this was a previous problem because I've only put 5k miles on the truck and do not know the rear diff history. I suspect it is current because I have a "hum or whine" driving around.
Zmann
I would take it in
or investigate on your own but that crush washer and nut spec is like 400 ft lbs
so you might want to have it looked over by an expert
smokin99stroke
Orlando, FL
Can't find anything about 400lb torques, but I certainly don't know where to start as far as backlash and preload and that stuff goes.... Thinking I'll pull the axle and take it in
Zmann
I may be wrong on the spec in may be a different procedure
I didn't open the manual and My manual is for a 10.5 sterling I think you might have the 10.25 version
but I would have it looked at if it were mine
7.3 Cowboy
Mske sure your ring gear bolts are tight to the diff I had a couple come loose and take out my rear axle on my old 02
