Reverse Delay
15Platinum67
Hey guys I have a 2006 with 133,000 lately I have been noticing a 1-1.5 second Delay only when switching to reverse and once it kicks in it will jerk anyone ever experience this before? Would appreciate some input thanks guys!
typically a sign of the direct clutches failing. Could also be a sticking solenoid (either from loose clutch material or fatigue). Drain and remove the pan, see mow much material is on the magnet ring. replace the fan filter and replace the direct solenoid with an OEM Ford unit. Refill the trans and test.
