s371FMW & S591sx compounds w/ 350/150s
JGman141
Ohio
Sounds like a nice set up, I would look into a bigger low pressure though. 350 injectors push a lot of fuel and you'll need every pound you can get.
6 L chevy eater
Franklin, VA
I keep hearing so many diff opinions.....s400 s500..,,, which way to go? Would still like to be able to drive to truck and it be reasonably responsive , I know there some guys that build compound set ups and are running some... I just don't know what to use a LP
windrunner408
I don't think it'll be any laggier than your setup already is and if you keep the nozzle size down with some good tuning, it shouldn't be a smokey mess either.
Gotta say I'm excited to see where you take this Charlie especially with some SPRAY...LOL LOL LOL LOL LOL
Craig@MFI
When we ran 10.40 on fuel in whitey a few years ago it was a s475/87 over a s595 and spooled great and stayed cool
Sent from my SAMSUNG-SM-N900A using Tapatalk
Craig@MFI
S371 will spool very quick! But I would pair it with a s488 instead
BlueWaffle
Grapevine, TX
The two previous posts, what charger would u guys run as low psi with the 71 as the high psi?
Personally, I wouldn't ever run 71 as a hp. Why go so big when you can still make a ton of power with a much smaller setup, spool and drive well on the street, and take a big shot of n2o at the track when needed?
kyle43335
What may i ask is your idea of "spooled great"? I would tend to say it spooled great at the track on the lights, burning against a loose converter. that setup on the street would be useless...
