I've run the performance/extreme for a bit. Seemed fairly well mannered, but would have turned sideways at 45-50 with the wet streets had it not been for traction control. Ran it a bit with dry streets. Would break the tire loose when punched at 15 mph. 28-29 psi boost.
Ran the tow tune to Houston & back its well mannered too and got about a half mpg better than stock. That could have been a fluke, though I tried to drive about the same on both trips.
Haven't run the street tune yet. Tow seems to run much better around town. The performance was definitely different at the higher RPMs.
Doesn't look like it will change tire size over stock, but will do smaller.
