Silicone body mounts
DEEZUZ
NO PUKESTERS
NWI
Are these a gimic?
Racer71
No they make truck ride so nice. I was skeptical for the money involved but the fitment and design is top notch.
Racer71
When I did mine the no limit ones were out of stock so bought the s&b.
They definitely are very nice, maybe I’ll get to install some no limits for a customer sometime to compare
Racer71
I was a fabrication engineer for ford/visteon when I got out of college and you’d be hard pressed to build/design a nicer set of mounts than s&b did. After taking a Chevy guy a ride before-after he wants them to make them for the chevs
DEEZUZ
NO PUKESTERS
NWI
Sounds like Someone needs to make an intro/ride thread.
joebuck
I am installing the S&B set currently on my truck, they look FAR superior to the OEM ones I’m pulling out can’t wait to see if/what the ride change will be.
joebuck
I have all but the middle ones on both sides installed those are being a bitch to remove to say the least, all the bolts came out fine and all of the old mounts came out but those 2 are stuck for sole damn reason, anyone else experience this? Or have any tips/tricks to getting these out? There different then all the other mounts also if that matters
joebuck
from what ive seen it looks like the middle (towards the rear) have a hex style fitting that the bolt passes through that almost looks like it unscrews from the upper part of the mount, Did anyone else see or do this?
joebuck
So a follow up, My middle (towards the rear) were rusted together so i had to cut them off by using a bottle jack to push the bottom of the mount up enough that i could cut through the middle shank, After that they went in smooth and easy, and the ride quality is worth the $ IMO
