Truck started knocking back at the beginning of January. Sounded bad, couldn't pinpoint what it was so I parked it to tear it down. Was hoping/expecting it to be a lifter, but once I got the heads off all the lifters and cam lobes looked great. Proceeded to take a look at the pistons and noticed that the #1 piston didn't come proud of the deck when it was at TDC, and it seemed to sit a tad crooked in the bore. When I turned it over by hand, it stuck when #1 reached BDC and I wasn't able to turn it any further. I took the block out and tore it down, the #1 rod was bent just enough to cause the bottom of the piston to contact the counterweight on the crank.
Just ordered a set of IH HD pistons with coatings, cam, bearings, full seal/gasket kit, a rod, and BD manifolds/uppipes. Was going to go with a single but I'm still not sold on the current tuning options and driveability of them. Will keep this thread updated as I make progress on it.
