OBSWIZ
These are U.S. Alcoa 6061t6 billet aluminum, Lifetime warrantee, hub-centric and wheel-centric The spacers are roughly 3-5 times stronger than the Ford cast 20" wheels .
We also have Steel spacers if wanted same Warrantee and price.
2" spacers will work without needing to cut off your existing wheel studs for those wanting to use '05 up 6" BS wheels on earlier trucks that had 4.5" BS wheels.
We can get you 1.25-1.5" spacers but you will have to trim the studs shorter.
But then the back space with then be 4.5" and the rim will set like factory.
PM or Email me for pricing.
Thanks, Cary
Thanks, Cary
