SRP1
OBSWIZ
Wellington NV
We have the new SRP1.1 HPOP in stock..ready to ship.
The SRP1.1 was designed for those of you running just about any size "A-code" injector. We recommend this pump for trucks running up to your average stage II non-hybrid injector or stage III 300cc "A-code" hybrid injector. This pump utilizes the factory IPR valve and mounting gasket. Our pumps feature a IPR filter screen to prevent IPR valves from sticking and fouling. These pumps are an axial 7 piston pump design. Our pistons are larger than stock and that is how we increase our displacement. Stealth is the only HPOP company that is manufacturing larger pistons and new cylinder blocks. Some of our competitors are increasing displacement by adding swash plate angle. SRP1.1 pump retain the stock 17 degree swashplate for ultimate reliability. We have engineered this pump with the highest grade materials available. These pumps are built to last. Our pumps are one of the most streetable and reliable pumps on the market. We feel that our new SRP1.1 pumps are so reliable that we are backing them with a industry first Limited Lifetime Warranty**. Our warranty covers the entire pump unlike some competitors products that only cover non-moving parts. These pumps will fit a 95' to 03' Ford Super Duty with no modifications what so ever. The SRP1.1 pumps are shipped with a new pump mounting gasket and new IPR valve o-rings.
Pm me.
OBSWIZ
Wellington NV
Should do fine, old version held 300/200% 647HP 2980 psi @35%..difference is new one has a 17* swash plate rather than a 18*..I wouldn't expect to see much difference.
